Rim compatibility
gerhed
Jason
Y'all recon these tires will fit the stock rims ok?
gerhed
Jason
I just realized I'm hijacking this post. I apologize and will post my question in a new thread. Again, apologies.
Oldbear42
Linden, Alberta, Canada
Shaine
C20 LWB Scottsdale
Here are the notes from my trie/wheel hunting. I also had the 16.5 rims and wanted to keep the steel rims to run the dog-dish hubcaps. One of my coworkers has an almost unhealthy Dodge addiction and was going to give me a set of steelies from his piles. He found the aluminum there and sold the set to me for a "song and dance." I spent an hour or so polishing each rim (over a few evenings), and I'm happy with the result. I got cheap rubber from my local Canadian Tire. They had them in stock, and I got the rubber mounted on the rims before I was out of my doctor's appointment.
16" Wheel (-0.5" from original)
  • Wheel 16 in x 8 in at Cdn Tire
  • Bolt Pattern, 8 x 6.5" (165.1 mm)
17" Wheel (+0.5" from original)
  • Wheel 17 in x 9 in at Cdn Tire
Optional donors:
  • 2007-2014 STEEL EXPRESS 2500 VAN 16 x 6.5J, 8 BOLTS WHEEL
  • GMC Sierra 2500HD (1999-2010)
  • Chevrolet Silverado 2500 HD [2001-2010]
  • CHEVROLET SILVERADO 2500HD / 3500HD (SRW) 2007-2010
  • Dodge 2500-3500?
Tire information:
  • Original size 8.75R16.5LT
    • Circ: 92.6"
    • Dia. 29.5"
    • Width: 8.8"
  • Tires purchased on April 22, 2024
    • Close to original - 245/70R16
    • Dia. 29.5"
    • Width: 9.6"
Catbox
Peter
C20 Silverado Camper Special
I would also recommend the step up to the 17 inch size now that it has been brought up.
I needed a set of wheels for my daily and the tire guy said they didn't have any in stock.
He asked if I would want to step up to the 17 inch size as they have a set of wheels in stock as well as the tires I wanted.
So now our daily sub rolls on 17's.
mran613
TN
Mark
V20
Thank you for all of the feedback and advice. As I have no idea what the bolt pattern, backspacing, etc. should be can you please let me know if these rims fit my 1987 V20?
Condition
Remanufactured
Seller Notes
“BACK SPACE 5" POWDER COAT #2 BLEM”
Backspace
5"
Hub Bore
4.6
Number of Bolts
8
Rim Material
Steel
Wheel Style
Full Face
Color
White
Items Included
NONE
Manufacturer Part Number
WE08008-2 White Blem
Quantity
Rim Diameter
16
Bolt Pattern
8x6.5
Wheel Material
Steel
Wheel Construction
Two Piece
Offset
32
Brand
Wheels Expesss Inc.
Backspacing
5 in
Rim Width
6.5
Lug Size
9/16
Finish
Painted
Auburn, Washington
Condition
Remanufactured
Seller Notes
Backspace
5"
Hub Bore
4.6
Number of Bolts
8
Rim Material
Steel
Wheel Style
Full Face
Color
White
Items Included
NONE
Quantity
Rim Diameter
16
Bolt Pattern
8x6.5
Wheel Material
Steel
Wheel Construction
Two Piece
Offset
32
Brand
Wheels Expesss Inc.
Backspacing
5 in
Rim Width
6.5
Lug Size
9/16
Finish
Painted
Do some comparing on a wheel size calculator to understand better.
You didn’t even post the width but guessing 16x10 0 offset based on the 5” bs.
Answer is maybe and likely fine but need to know tire size and truck lift.
85K304SPD
Las Cruces, NM
Richard
Measure the back space on the wheels that are on there now and decide from there. You might as well buy a full set of the 16s now, ditch the 16.5s all the way.
RanchWelder
Earth
Blazer
355ci
Yup... Grit Dog.
Love that calculator:
https://tiresize.com/calculator/
Unless it is strictly an off road ranch truck, avoid anything that says it's a BLEM, unless you can inspect in person. With the tires sometimes coming in need of added weights, you cannot afford to get a warped or bent wheel, unless you want to eat your new tires up.
HowPoison
