Right rear locking up long before other brakes applied..
MikeB
Had something similar happen on a 74 Chevy van. Not as bad as yours, but one of the rear wheels would tend to lock up on medium to heavy braking. I couldn't find anything wrong so took it to a shop. They guys there couldn't find anything wrong, but sprayed (more like hosed down) the shoes on both sides with brake cleaner. That did the trick. Must have been some kind of contaminant on the shoes.???
Christian Nelson
Wisconsin
Christian
K15
Finally got this fixed. After I blew the brake line, and replaced it with a nickel copper one so it won't rust out again.. I discovered that the caliper bleeder was broken off. So, I went to the parts store for a new caliper, got two, since they were only $16 each.. Then, I discovered the pads were really thin.. So, I got those too..
Anyway, after getting that all put together, and bled out, and all, the rear is no longer the first thing that locks up, the brakes work great now!
gwcrim
Ohio
George
So bad front pads were the culprit? Interesting.
kr155
