Resurrecting Clifford the big red 87 R3500
Georgeb
Wisconsin
George
K10 Burb Z71
Cool!
MadOgre
NA
NA
NA
NA
NA
Besides there is nothing that a BFH wont fix :)
MadOgre
NA
NA
NA
NA
NA
PS those wreckers always seem to have nice dashes in them FYI
Georgeb
Wisconsin
George
K10 Burb Z71
So during lunch I took a look at my coolant level and it has now gone down below the full cold line. It took 3 weeks of daily driving since the manifold reseal. Here I hoped the crack in the block was superficial and the coolant use would stop with any luck. It doesn't look that way tho so another motor is still on the list. Well It was anyway but I kind of glossed over it. Kinda got me down on the whole project.
:suicide:
Georgeb
Wisconsin
George
K10 Burb Z71
:suicide:
So I cried a sob story about it to the wife and she told me to go out and buy a $30,000+ truck and have that rust out in 5 years even if I wash it like the neighbors truck. She asked if that was in the budget??? In other words she said "Suck it up buttercup and keep building!" I love that woman!! Like when I told her my engine was doomed she said "Now you get to buy one you want or build a HOT one if you like"!!!
:love62:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
:love62:
Sounds like a keeper!
MadOgre
NA
NA
NA
NA
NA
No Kidding!!!
Georgeb
Wisconsin
George
K10 Burb Z71
UGH! Stupid PO!
Georgeb
Wisconsin
George
K10 Burb Z71
Making some progress.:party36:
I also have a bunch of extra parts to sell.
Georgeb
Wisconsin
George
K10 Burb Z71
The rust tha MUST be stopped! This seems to me to be the most vulnerable spot on these cabs. On the last cab I repired I eliminated this channel. Mot sure yet what I will do on this one. If I keep the channel I will have to check on it at least once a year to keep it from rotting for sure. I wish GM would have done this different.
firebane
Calgary, AB
Curtis
I think one of the biggest issues with not only these trucks but a lot of trucks from the GMT400 era was not only that channel but the fact they would put screws right through the sheet metal do a piss poor job in protecting it. Then you get moisture all god knows what else up there causing grief.
Georgeb
Wisconsin
George
K10 Burb Z71
Yeah, along with whatever comes off your feet inside all runs over there where it soaks into the floor insulation and sits in the channel. Add to that moisture wicking up from inside the rocker. Once its wet it never ever dries out.
Georgeb
Wisconsin
George
K10 Burb Z71
Put my gantry crane up for lifting the cabs and such. Not meant for a lot of weight but it works well for cabs and boxes.
MadOgre
NA
NA
NA
NA
NA
I would tell you to use POR15 but everyone seems to be getting their panties ruffled about using POR15 for some reason. But I Used it on mine and it doesn't rust no matter how much moisture it sees! Have to apply it to bare metal and chemically convert the rust first though. Just follow the directions and it will never rust again!
And yes you can paint over it with an etching primer and then paint.
Georgeb
Wisconsin
George
K10 Burb Z71
@ MadO, I see everyone getting all wound up about POR. I plan on using it on the floor pans and in the channel after a good blasting.
BrickBlazer
