Replacing Harmonic Balancer
Yep, looks like the pump has coolant streaming out the weep hole or around the shaft.
An SBC developing a crack in the crank pulley - where it is bolted to the balancer hub - is hardly a rare occurrence. Here is a stock image:
Cracks can also form in the grooves of the belt drive section. Here is an example (this one was found in the pulley of an engine I was rebuilding):
Either type will cause vibration/runout of the pulley - as well as abnormal performance and reduced life of the associated belts. But, while a cracked pulley is certainly serious (and should be dealt with ASAP), it isn't nearly as critical as losing the "interference fit" of the balancer hub to the crank snout.
An interference fit means that after the two parts are assembled, they essentially become one component - with zero clearance or relative motion. In theory, the crank bolt is only required for assembly purposes and the key is only for timing mark alignment. Point is, there should never be any observable play between the balancer hub and crank snout. So it's kind of alarming when you state:
The balancer moves, too, just not as much.
Like Mason says, the sheave is only fastened to the balancer in the area of the hub:
So, if you are able to create motion - in the outer ring of the balancer - when applying force to the pulley... it becomes a serious issue. If allowed to continue, it's possible that the crank snout could be damaged - and trust me, you don't want to deal with that.
Actually, that crack in the ribbed part of the pulley isn't a crack. Some versions of those pulleys were made that way, it's just a seem. It's at an angle on all of them, to keep from causing a noise every revolution I guess.
Got it off. The dampener was all cracked up and bulging out. Seems like pretty rotten performance for a nine year old part. There's a number on it, but the PO told me that this was a Jasper crate motor installed down the highway from me. I don't know what brands they use during reassembly or what they reuse, but there you have it. I noticed RTV on the male portion of the balancer keyway. Is that normal or useless?
Finally, thanks to my little buddy here for keeping me warm in the freezing weather.
@74 Shortbed @Honky Kong jr
74 Shortbed
I need to get something like that..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Shouldn’t need RTV in the keyway unless it’s worn out.
You're exactly right. It doesn't come all the way to the end of the snout. The RTV picks up where the metal leaves off.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I was thinking of getting the ones that go directly on a propane tank..
This is what I use, along with a fan to circulate
It's great. This is what it says it uses. I put farm diesel in it because I think that's the cheapest of those options, which is $2.32/gallon here at the moment. Kerosene is about double the price of farm diesel/gallon here, and Jet A is probably around triple. I don't know how much heating oil costs per gallon, though.
GorillaHumper
