Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I have a 4 core waiting to be installed in Crusty Biscuit. I'll have to modify the cradles for the bigger tanks, but better cooling is a must in the triple digits temps, especially when it'll be a vortec setup. I'm keeping an eye on the electric fan installations I see on various threads so I can add that too. Had the radiator reconditioned at a local shop for $95 out the door. I take all my raditaors to them and they've always been reasonable and do good work. $260 seems steep, but it's like new and fits like it's supposed to without modifications.
I've been back and forth in my head about the fan setup for my truck. I've yet to find an e-fan that will cover the radiator cleanly. I thought about cutting my oem shroud to accept a fan but the oem hole is ~22" circle for this size radiator. that means the fan has to be at least that height to cover the existing hole with a 30ish" x 22" rectanglular cutout.
i decided to get a clutch fan that will fit the oem shroud for now until I can find an e-fan that fits for less than $300, if possible. it keeps me from hacking up my shroud. If I remember correctly, they take ~7hp according to engine masters. I think a 45 amp e-fan would take less than 1 hp through the high amp alternators required to run all this extra stuff.
