EvilGenius
- May 12, 2016
- Metro Detroit
- Darien
- K10
As long as you aren't a super scrawny guy and this is a 208 tcase, you don't need a jack to pull it off. When all 6 bolts are removed holding the case to the adapter it will still hang up there on the input shaft. Get a good grip on it and you can slide it off and lift it to the ground. With it being an aluminum case it isn't real heavy. I just pulled mine by myself last week.
