Removing Pilot Bearing//Is it as bad as I hear?
SquareRoot
With the NV4500/205 rebuild complete, I'll be doing the ol' swaparoo soon. When I pull the current trans, I'm going to replace the pilot bushing/bearing. I have read horror stories about getting out of the crank. And, I have seen the "bread trick" debunked on TV (Roadkill) I think, so don't pull that one over on me!
Thanks in advance. Oh and FWIW, I'm installing a Moroso Sealed Bearing. I've read great things about them vs the bronze bush :)
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
If you can't get a small puller (SnapOn etc has those) in there, find a shaft that is similar to the diameter of the input shaft. Pack a bunch of grease from the greasegun in the hole, fill it up. Put the shaft into the hole and hammer the punch. Bearing should hydraulic out.
Bennyt
Surprise
Ben
I've never had an issue getting them out. Either the grease trick mentioned above, the puller hook, and 1-2x it was seated all the way in and I tapped it and threaded a bolt in and it forced it out.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The bread trick actually works, I think I prefer it over grease since it tries to escape less and not as expensive lol.
The bushings always seem to be easily removed for me. The bearing type though, they tend to break apart using a puller. The grease trick and also the threading in a bolt trick definitely works.
SquareRoot
I'll try the grease method as several of you seem to agree on it. I think I have the a tool...the old input shaft from the trans should work perfect. Thanks fellas. You know saving all the used parts is a great idea. I used several of the old bearing races, cut a slot in it with a cut-off wheel and viola' the perfect tool to press in the new bearings. Quite a collection I've amassed.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
1st one We pulled as kids was a steel ball bearing rusted in the crank of a 53 ford was a hell of job, ended up cutting it off input shaft with a grinder. Have never had a bad one since. lol. We had to remove clutch, bellhouseing to get tranns out, The old cars YOU could take pan off bottom of bell housing.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Bronze bushing will run forever.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
OLD input shaft won't work You need a LONG shaft to push all the grease in.
350 w/203
Grease method always worked for me. Once you go bearing, you'll never be swearing!
WFO
Texas Panhandle
Bread has always worked for me. I use a long bolt that will barely fit in the bushing, with the threaded part cut off, for the driver.
Plus there's no greasy mess.
NBD Use wet paper towels pack as many in as you can use a dowel an extension whatever to pound on the towels through the bearing hole,put in more towels if you have to. Same principle as using grease but not as messy.If it's a bushing not a bearing run a tap through it until the tap bottoms in the crank,keep turning the tap the bushing will walk up th tap.
DonnieM
