SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
I'm adding 3 degree shims to my rear springs. The pins they sent with them are the same length (4 inch) as what is currently in the spring pack and won't be long enough with the shim. No big deal as I have been wanting to remove a leaf to "unstiffen" the ride slightly. That will solve the pin issue but which leaf is the correct one to remove? Obviously not the top or bottom but I would think the shorter ones on the bottom would have more an effect on overall stiffness?
