Remember When I was asking for help from anyone locally!. Pic's inside.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Is there a way to tell what gear I have with the Diff cover off?
I never found anyone who could help me. The rear end would pop/snap
like it was busting gears when I turned only. Horrible sound. I took the cover off
today and (DAMN) its gone. The spider gears. $1400 for a rebuild :oops:
It looks like it was rebuilt not long ago. See all the yellow on the gears. I bet it
was back yard built by someone who did not do this before!!
I just noticed the bolt that holds the center pin is missing but is not in the housing! o_O
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Wtf lol... don't need a bolt if you mushroom both ends of the center pin :rofl: colored rtv is always the signature of a true craftsman :anitoof:
There should be markings on the ring gear that tell you gear ratio. Or just count teeth on ring and pinion and divide. The pin for the cross shaft quite often breaks off when you go to remove it,probe with a pick,I'll bet 1/2 of it is still in the hole. You should heat that area with propane before trying to loosen the pin.
Turbo4whl
Downingtown, PA
Wayne
If the pin part of the bolt is still in hole as Rick stated, you can drill it out. Remove just the right side bearing cap, then with a longer drill bit, there is clearance to drill it out.
SquareRoot
I wouldn't waste any time or money on that. Buy a 14 bolt and be done with it. If you liked the way it sounded and felt before it grenaded, you'll love a Detroit Locker!
Auburn, Washington
^ Lol at the noise comment.
Agree, complete axles in good working condition are just too plentiful and cheap to fck with rebuilding that. ESPECIALLY since you’re not talking diy. You could buy and replace like 4 or 5 of them (not including labor) for what you were quoted for a rebuild. And only have to touch easy bolt on parts like u bolts and brakes.
Fat 454
Australia
C20 Suburban
( owner to Back yard mechanic ) - " not sure but I don't think the gear teeth should look like that should they ? " - here, shove in these bananas and sawdust and button'er back up ..
Ssshhhh.... bananas and sawdust is a trade secret anymore. You are giving it way, lol.
WaterboyCrewCab
