scenic760
- Jan 12, 2021
- SoCal
- Chris
- Suburban K10
Personally I would be pissed my virgin block was ruined and I would want that to be made right. I would want at least a .020 over block if not a replacement virgin block or a lot of money off. Especially without being contacted, but again that's me and you may have had certain miscommunications with them.
They should at least give you a really good discount, or not charge for labor for the sleeves and a small discount. But yes you did get quite a bit of work done so the number isn't crazy far off, it's just the situation.
Exactly as you said, it's now .060 over so you can't rebuild it again, unless you do all eight sleeves, which is out of the question for a normal small block.
100% that is what I'm most pissed about... now you have the distrust issue on top of it... I'm not sure I would trust them to deliver me a .020 built long block under the circumstances
