- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
My main concern was that they gave you a quote and then the final bill was substantially more. Without having seen the block its hard to say why it needed two sleeves. But ..... I have seen plenty of standard bore engines that were left sitting with water in a couple of cylinders and ended up either needing sleeves or a new block.
The $3200 final price is not all that bad. Its hard to build an engine and stand behind it for much less than that now days.
Bottom line is that they should have called you before doing anything above the original estimate.
That's where I'm at on it too. That's why I told him to return it and dispute. They cleaned, inspected, and gave him a quote based on that inspection and agreed upon work. Then they just magically had to do a bunch more work and charged him $1000 more for screwing up his motor without actually talking to him about it.... no thank you. I'm not sure how you "get carried away" and just bore a street block that far over and then keep "getting carried away" enough to sleeve two bores on a basic 350 block without talking to the customer, but it sounds an awful lot like incompetence or a scam to me. Its been quite a while since I've lived there and my memory isn't what it used to be but I thought it used to be illegal in California for them to not give you a written quote before work was done and also to charge you more than the agreed upon amount.
