jfrancom101
- Jan 3, 2022
- Idaho
- Jeff
- 2500 sierra
So I am rebuilding a sbc 5.7, and this is a more general question but I figured some of you might know. I bought a rebuilt crankshaft which came with the resized bearings and while putting each one on I try to turn the crankshaft over by hand to make sure that it is still free moving. Well I got twp pistons installed and tightened down and there is more resistance due to the new rings, but once I put the third piston on the crank shaft is almost completely locked up. I tried loosening the bolts slight and it turned again but as soon as I tighten the bolts (not with a torque wrench but probably only 20 ibs pressure) the crank is locked up again. I tried pulling out the 3rd pistons and skipping to the 4th and the same thing happened. What could be causing that? I am using assembly lube the the first two installed rather nicely.
Though if I really push hard the crank will move a few degrees, it is a lot tighter than iv'e ever seen before and it seems to be just at the main bearing. Help?
