Rear wheels locking up.
85chevydually
Philadelphia
Scott
C30
I have a 1985 chevy c30 dually. For some reason after the truck has sat for a couple hours the rear wheels lock up. I can't go forward but i can go backward fine and usually i have to go backwards to unstick them and then i can go forwards. Any ideas? Also i am not using the emergency brake.
Notice any wetness around the back of the drums?
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
Had one do that while back and the rubber line from frame to axle had a blister inside of it.
85chevydually
Philadelphia
Scott
C30
i'll check tomorrow its dark out right now. thank you for the quick response
Could be brake fluid or axle fluid on the linings making it grab. Or a bad hose like towman mentioned. Plus we had that drop in temp this week after that storm, if you got water in there and it's damp with the cold it could do that. Mine does that a little bit when it is cold and damp, once in a while in the right conditions.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Also check to make sure someone didn't put the shoes in backwards. The "long shoe" (the one with the longest brake lining) ALWAYS goes towards the rear of the vehicle.
Silv22
