Rear sway bar
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I just found that the rear sway bar from a 98 s10 blazer will workwith my 10 bolt rear and line up to the frame. Id just need to drill holes in the frame and figure out what end links to use.
Good to know this thanks... but it's designed for a much lighter truck... they are too weak and will do little to nothing other than entertain you as it's installed.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
S10 Blazer/Jimmy 2 doors fit perfect! since i have a 7 inch drop in the back i install the bar up side down, and man that change my ride! more stable on pot hole, in curve, and even in accelaration :)
total cost: $17 for the SB and $20 for new 95 S10 front end link! :D
I'm with challenge you actually feel it makes a difference. To my way of thinking it's too small a diameter spring steel to do much. Also the design... if you were to straighten it out it would be twice the width. The longer a spring the less rate.
Anyway, it would be nice to get another review after you have lived with it for more time.
350 w/203
Has anyone EVER seen or have pics of a 2nd Gen Blazer (or Jimmy), with a full removable top, 4WD with a rear sway bar?
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
2005 Z52 4x4 VS my plain jane C10 weight will be close i think and for now the ride is way better mosly in thigh corner.. i know is not the big autocross bar but for the low budget ingenering that i love try to achive is a good start.....just add extended shock braket, ride is even better continue to try/error to play with it! :)
73c20jim
Tombstone, AZ
Don't need no stinkin' swaybar.
I could replace my rear springs with concrete block for a softer ride.
350 w/203
That's pretty effin' drastic. You're gonna have to move to the South if you're going to put it on cinder blocks.
350 w/203
Nobody?
MikeB
I just ordered this Addco #202 rear sway bar from Summit Racing. Will report back on the Addco's fit and performance.
Well, I ended up returning the Addco sway bar. It's designed for the end links to attach to the leaf spring u-bolts using an adapter bracket, and the center section attaches to the frame rails. Very unusual.
However, I could not make it fit after 2-3 hours of trying. Thank goodness I bought it from Summit Racing where returns are super easy and they pay the return shipping charge. Kinda sad, because I have used Addco's bars in the past, and was hoping this one would work.:(
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Curb weight on a 77 c10 starts at 3620# and goes up depending on options. mine is about 4300# give or take (350 A/C Silverado package) . A 97 Blazer with 4x4 has a curb weight of about 4045# https://www.automobile-catalog.com/...blazer_2gen/s-10_blazer_2gen_5-door/1997.html Looks plenty close to me.
78C10BigTen
pennsylvannia
C10 BIG TEN
Do the s10 end links still reach if you put the sway bar on the right way?
Poppy 87
Bloomingdale GA
R10 Silverado
1987 R10 Silverado short bed, front sway bar 1 1/8" factory, no rear bar
Sent from my XT1254 using Tapatalk
seanhatesregister
