Rear sway bar
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Rear sway bar for our square not many option! Belltech got one model but a bit expensive!
any idies of witch one i can fit from other GM model or other (Dodge,Ford ect...) thx again for your help! :)
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
One from a S10 blazer might work. The width lines up with the frame rails.
Nonstop
Ca
Nick
K2500
Something like this maybe... https://www.classicindustries.com/product/1978/chevrolet/truck/parts/rsb471.html.
Think maybe factory bar for c20 or c30 that were the camper special models, maybe suburban would work too.
I put a factory one on a K20 about a year or so ago. Frankly, it was a pain in the ass. It certainly helps, but needed new u bolts, plates, took some grinding, and the axle tubes are a different size than the 10 bolt. Probably best to go with the after market.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
This is awesome, I've been wanting to put a rear bar on the burb for years now
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
If you want a Hellwig bar you shouldn't wait too much longer, they are out of production and no longer listed on their site. There are still a few around and the cheapest price I've found is $213 w/free shipping. Check Ebay or Jegs for Hellwig 7535.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
yes not easy but works! it fun to play around....too easy will be boring! :D
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
For me...over $100 for a rear sway bar kit is over price..it a simple technique to fit one...and so cheap to find in the junckyard....but its just my opinion! ;)
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Depends on your access to a decent junkyard. Closest one to me is a 45 minute drive and it’s 90% imports. Last time I was there they only had two well-stripped squares. Space at junkyards is like space at the grocery stores, they get filled with what sells and squarebody parts won’t keep them in business.
MikeB
North Texas
I've been wanting to get the Hellwig model for lowered trucks, although the only difference may be shorter end links. I do like the tension adjustability though.
That Addco bar sure looks different. No bend to clear the center section of the axle. I wonder how it mounts.??? Just noticed Summit and Jeg's show a different picture.
Edit 10/11/2019: Turns out the Summit and Jeg's pictures are correct. Addco sent me this picture.
82Diesel
USA
6.2L
Very interesting. Rear? Odd. Maybe for suburbans or duallys?
Sent from my LM-X420 using Tapatalk
MartinK5
