- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Did you check the back lash? Looks like way to much. Need to move the ring gear closer to the pinion.
Unfortunately I paid $1,450 for the truck,
wow...in Austria you would have paid 7000-10000$ for a truck like this...
Installing a limited slip or trutrac differential is the same work as spool or open diff. I would think about it.
I'm running eaton limited slip diffs, they can be tuned to your liking with different springs and clutches.
A right done rear end will hold up like forever except you abuse it with high power or burn it.
https://www.summitracing.com/parts/dtl-913a315
https://www.summitracing.com/parts/etn-19587-010
