JJFz6r
- Apr 16, 2013
- Ottawa, Ontario
- Jeremie
- K10
- 400 ci
Hello everyone, I am just getting familiarized with my square body and I know some of these questions were answered in diverse other posts so sorry if you guys have to repeat yourselves but this is to bring it all together. My truck is currently equipped with a 4 inch lift, springs in the front and blocks in the rear. Now I was looking at adding an extra inch for tire clearance since the guy before me had felt it bump the fender with the 35's that are on it right now. So I was looking into an EZ inch/zero rate and was wondering what other components need to be purchased separably with them such as longer Ubolts and heard of some people talk about shims? And I just got a new longer driveshaft built, would the moving of the axle front or back 1 inch with the 1 inch lift require some modifications there? Last but not least some people believe you should never put blocks up front or double blocks in the rear, now would these be exempt from that since they are like an add a leaf that don't change the rate? Or should I ditch the rear blocks and put these shackle flips (http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=125), and what would be the requirement for the shackle flip as in drive shaft same length as with the blocks and stock springs ok? Again thanks guys for your time
