Radiator mounts
Charlie Kleman
Johnstown, PA
Charlie
Anybody know of anywhere that sells radiator mounts to fit a 78 4x4? LMC says they’re on back order indefinitely, evilest sells them but they’re over $100 with shipping which feels a little pricey, and everything else I’ve seen you have to buy the whole body mount set.
Scott91370
Burleson, Tx
Scott
Sierra1500
Do you mean part 11 here? I know it says for 81-87 but I don't know if there is a difference in pre 81 or not.
If so, I am 99.9% sure I have a set I'd let go, just let me know and we'll work something out. I do not have the rubber support pads though.
pic?
Charlie Kleman
Johnstown, PA
Charlie
the rubber is actually what I need, thanks though
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
ILl be at the shop here in a few hours. I have an 82 cab that may have the rubber mounts. If not I can at least get you some pics of the ones about to go in my 84 and you can make something that will work. there basically just shaped rubber feet that keep it from rattling around anyway so you could make your own from a low shore range D epoxy...just make sure to stay between 30-50 durometer because it starts to get too hard around 60-70d
Carb'ed Vortec 350
Which part? 9? 10? 11? What company is "evilest"? Never heard of them, but many could get called that.
your picture doesnt help me know what you are speaking of. you mean the rubber itself? I thought you meant the rail it rests in
Scott91370
Burleson, Tx
Scott
Sierra1500
That was my pic because I forgot to post it earlier. But the OP said the rubber part. Part #9
Carb'ed Vortec 350
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
you can use any '67-87/91 trucks and G series van ones, 4 core ones are largest and bigger than all the others.. all these years. the way they mount changed between 67-72 and 73-80 and 81-up but the cushions themselves are all same style design. just different lengths of them for sizes of radiators, IE thickness of tanks at the tank to core seams
here you go:
http://www.usa1industries.com/1973-87-fullsize-chevy-gmc-truck-4-core-radiator-cushion-set-of-4.html
http://www.usa1industries.com/1973-80-fullsize-chevy-gmc-truck-2-core-radiator-cushion-set-of-4.html
https://www.summitracing.com/parts/opg-s240947
https://www.summitracing.com/parts/opg-ulr004
https://www.summitracing.com/parts/gmk-4012-326682s
https://www.summitracing.com/parts/gmk-4012-326681s
https://www.summitracing.com/parts/sum-380665
https://www.summitracing.com/parts/opg-ulr003
https://www.summitracing.com/parts/opg-ulr005
dorman universal radiator insulator mount cushions you can custom make any length size you need:
DORMAN 10665
get them through auto zone or oreilly auto or rockauto
the placement horizontally is disctated on top by the cover plate, the buttom ones just rest under the radiator i think. or at least thats how my gpa put them in :p
JUKA
