r3500 new lower control arms wont take grease??
charlesg
wisconsin
charles
k3500
Tried lubing them and they wont take grease, changed zerks too, does the weight need to be off them??
Thanks!
TravisB
Travis
Thanks!
Shouldn't need to be unweighted to grease them. I would have guessed the zerk fittings but if you changed them... is your grease gun the problem? With new ones I am not sure what to tell you. I have used some heat on old ones to soften old grease in the zerk but this doesn't really apply. I would try another gun.
mrgoodwrench
MN
mike
silverado
Sometimes if you tighten the grease zerk all the way in it will contact something on the inside and plugs the zerk try backing it off a little bit and try again also take your grease gun and pull the trigger a few times with it connected to nothing if grease comes out good if no grease comes out you have a problem with your grease gun either it's empty broken or has an air pocket excetera. Are you talking ball joint or control arm pivot bolt?
Sent from my SAMSUNG-SM-G930A using Tapatalk
jdickson
