Question on TCC ls swap 4l60e
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
So I am done with my ls swap 5.3 and drove the truck and so far it's all good. I have not got on the highway yet only got up to 35 mph.
My question is how do I know if I hooked up the TCC brake switch (blue pin 33) correctly. I used a relay that had 5 pins but the diagram in front of the relay is different looking than the LT1swap.com one it still has the same numbers and I matched all of them.
This is the relay I am using
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
when I press the brake I here the relay click and I release and it clicks again. Pin 87 on the relay is the only one I did not use. Everything else is matched to the lt1swap diagram. I just want to make sure I don't have a different type of relay that is doing something different.
yevgenievich
Place
Name
Year
Model
Size
Relay is same, should work if connected same. But brake switch from 98 camaro(and number of other gm vehicles) could have worked without needing the relay.
1sik78
Sparks,Nevada
Manuel
C10 pickup
250 inline 6
Thanks for checking on it. Will look into that 98 camaro switch in the future thanks
ben_swager
