Question about exhaust 5.3 LS Swap
jfkelley
Oklahoma City
I have an 1976 Chevrolet Scottsdale K10 , 5.3 / 4L60e / NP241C with 2015 Camaro stock manifolds ..My question is what Pipe can I scavenge from Salvage yard for my set up from exhaust flanges back ? Thanks in advance !
R Carnella
Long island
Rich
Suburban V2500
I don't know of a perfect salvage yard solution, maby someone else will chime in on that, but i wound up just welding together this Y-pipe.
I used a 2 into1 Collector and some pipe sections from summit racing. Didn't take very long and i made it fit perfectly.
dvdswan
Port Orchard, WA
Dave
You can create your own. It's a lot of back work if you don't have a lift, but very satisfying when you're done. Find some stock flanges and build back from there.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I used the 2010 Camaro exhaust manifolds on my swap in the 73. I bought the Camaro cat delete pipes. They had the O2 sensor bungs already in them. They exited past the trans mount.
iamtherealJayy
Tennessee
V20, K10, K10
In my 1978 k10, 4speed manual, 205 tcase, I ran the stock truck/Tahoe manifolds and downpipe but had the drivers side cut, rotated, and rewelded before the o2 sensor to clear the mechanical clutch linkage. I recently had my exhaust done by a local shop(I supplied all the tubing) they used 2-1/4 to tie the downpipes to 2.5” dual pipes.
jfkelley
Oklahoma City
I found a pair of BBK Cat Delete for 2014 Camaro SS on FB Market going to try them hoping they will clear everything on my K10 4x4
jfkelley
Oklahoma City
Well, the ones I bought won’t fit over mine transmission crossmember guess it’s different of 4 x 4… I will put these on Facebook market and just take it to a exhaust shop
seanhatesregister
