Q-Jet choke plate stuck open
raylanr
Campeche, MEX
Franc
So I have not been able to start my C30 in a while I thought it was the module for my HEI AND @RetroC10Sport help me replace it and it didn't start either. The other day I remove the rod that make the choke open and close so I could set the choke to the close position but I didn't succeeded either.
I did notice some kind of build up on the left side of the carburetor, and when moving the secondary plate by hand I notice that the spring next to the choke valve was not moving.
I know nothing about carburetors but I thought I would ask if I get a carb cleaner and replace this choke valve thing could I get it to start.
Oh I really don't know what that zip tie is holding together it was there when I bought the truck.
Or I will be better just getting a new carburetor.
These are pics of what I see.
Carb'ed Vortec 350
I know just enough about carburetors to get me in trouble. Hopefully some more knowledgeable member's will chime in to help. It does look pretty dirty like it could use a good cleaning and rebuild though.
raylanr
Campeche, MEX
Franc
yes it does, all that yellow gunk needs to be clean up. the spring over on the left side when I prime the secondary didn't stretch or anything.
I know nothing about it, been reading old post trying to get a grasp on things
I figure out I have a 4MV but that is all.
firebane
Calgary, AB
Curtis
What is up with the pull off canister on the passenger right side? It looks like its broken or has some wire wrapped around it?
Can you move the plunger for the pull off freely?
Carb'ed Vortec 350
I rebuilt mine with a quality kit from Cliff Ruggles, and I bought his book and some other literature and read it before tearing it down. Once I understood it better, it wasn't so bad. Just a lot of small pieces, and some adjustments to make on the bench and then fine tuning once it's installed. It might worth just rebuilding it and go from there.
raylanr
Campeche, MEX
Franc
Are you talking about that?
raylanr
Campeche, MEX
Franc
How much was the rebuild kit and book I wouldn't mind investing on something I can use more than once, but not that often either! lol
firebane
Calgary, AB
Curtis
Yes that part.
I ordered a rebuild kit from another site and with shipping cost me about $100. Took less than a day to rebuild the one I have.
raylanr
Campeche, MEX
Franc
Yes that part.
That's how it was when we remove plate and bowl to get to it. the spring that connectos to the pull off is completely stuck when I pull back to open the secondaries it didn't move at all.
Carb'ed Vortec 350
I paid about $50 for the kit and shipping. The book I think was $30 at the book store. I got the Doug Roe book as well, and a factory manual too. I think I spent just over $100 for the whole shabang. Between all three sources I felt totally comfortable rebuilding mine. His kits are very high quality, and he has other parts if needed. He may ask you to take some pictures of your setup so he knows what you're up against.
I even spoke with Cliff and he helped decipher a couple things I had questions about. He is a really busy guy, but his customer service is exceptional.
http://www.cliffshighperformance.com/carbkits.html
raylanr
Campeche, MEX
Franc
So you got the SR. for what I see on mine, I may need all the other parts that don't come in the kit. but I guess will be emailing him pics of it and see what he recommends. I'm in a budget to get this fix I hope it works and can get this truck moving once again!
firebane
Calgary, AB
Curtis
Well that is the choke pull off canister. The long part behind it SHOULD push into the canister freely. If this does not happen then something in that area is causing it to bind.
I would start in removing the pull off and freeing the linkages and go from tehre.
raylanr
Campeche, MEX
Franc
I should be able to use the carburetor cleaner to get things moving or should I just do it dry as it is?
firebane
Calgary, AB
Curtis
Everything should move freely without needing carb cleaner. And if you are going to do a rebuild then get a good degreaser to clean up everything.
raylanr
Campeche, MEX
Franc
I will try too get tip it after work.
I don't know what that zip tie is there and what is holding.it cpuld be the pull off canister but not sure
skarletjunkyard
