rich weyand
- May 28, 2014
- Bloomington Indiana
- Rich
- K10
OK, trying to refresh my aerodynamics, BUT....
I think that if the air velocity through your cooling fan at its controlled rpm is lower than the velocity of ram air through the radiator at speed, you will get more air flow at speed with the fan off than with it running. The fan is effectively slowing your ram air down to its CFM rating rather than letting it flow through at the full CFM that would pass through as ram air with the fan not there. The fan's rated CFM at idle and low speed is more than enough to cool the engine, but not enough when the engine is working to move the truck at higher speed. At that speed, the ram air would be enough to cool the engine, but the spinning fan is now in its way more than its helping.
You can test this by switching the fan off at speed and watching what the temp does. If you are at speed and at temp, shut the fan off. If the temp drops, you need a fan controller.
