Pusher fan(s)
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
This is the factory location. There were 4 pre-drilled holes from the factory on the radiator support. The fan is centered on the bottom of that opening. Due to the fact my truck is a big block, the radiator tanks are positioned outside of the openings. If you want a better picture, I can run down to the shop and snap some. I found this on my local CL. This is the same fan as mine.
https://sacramento.craigslist.org/pts/d/hot-rod-chevy-truck-parts-bbc/6605875533.html
So I take it that it is mounted in the lower part of the condenser?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Yes, but it mounts on the core support. You'll notice I had to replace the condenser with and aftermarket one. The original fit the whole opening. This one off sets to the passenger side, so the fan will cover more of it now.
yevgenievich
Place
Name
Year
Model
Size
Mine is aftermarket. I want to add one to the other side, and also change the trans cooler at some time.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Thanks.
That looks to be in the center right side of the condenser. Is that correct? When I add one just want to be sure that it needs to be centered or to the lower area for best results.
brad083
