"Proper Starting procedure" for Squarebody
Keith Seymore
Motor City
Keith Seymore
4.3L
Wrong wrong WRONG WRONG WRONG!!!
You don't grab the handle like that! If it kicks back that's how you get a broken wrist or arm.
You CRADLE the handle in your open hand(s). Bring it around until you feel compression, give it a quick pull up, and away you go.
K
...or drag the thing around in gear with a tow strap til it fires off...
:rolleyes:
jjester6000
Illinois
Jack
C1500
Damn, that sucks.
I'll be honest, I didn't actually spin a bearing, but I actually thought I had after hearing a horrible knocking noise. I still had oil pressure, so I drove the rest of the way home (Thank god I had the forsight to get real snow tires for the rear). and parked it for about a week. When I started it up again, I found that the noise was just the fan hitting the radiator support that was held in with bailing wire.
73c20jim
Tombstone, AZ
Race car was always perfectly tuned.
Agree. Very easy to start.
No choke. It just starts up every time.
Ninao
