Proper process for painting most of your interior parts
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Process for proper painting of most interior parts:
You will need:
1 CAN KLEAN-STRIP PREP-ALL
1 CAN KLEAN-STRIP BULLDOG ADHESION PROMOTER
2 CANS SEM COLOR COAT
STEP 1: Wash each part with regular dish washing soap and a brush, must get all the dirt and any silicone "interior dressing" off then dry each part completely. "I had my wife do this for me in the kitchen as she has so much free time, thanks babe!"
STEP 2: If the part is metal then use a 3M SCOTCH PAD to rough up the surface. With a lint free rag wipe the part down with PREP-ALL, let dry. "Skip this step if the part is plastic"
STEP 3 : For plastic wipe each part down with PREP-ALL and a lint free rag, let dry. This will remove the last of any silicone and dirt that the washing with soap did not remove.
STEP 4: Once dry then spray a lite coat of ADHESION PROMOTER to each part about 10 min before your ready to paint. This will give the paint something to bite to, also helps a bunch if it’s a plastic part as these may be flexed a bit after its painted.
STEP 5: Final step. Now apply the SEM COLOR COAT spray paint. Make sure the air temp is 60 degrees or higher and the product your painting is the same to the relevant air temp. I use lite coats at first but as these tend to dry fast I then put the costs on heaver so I can get an even and consistent sheen once dry.
All should be dry to the touch in 30 min and ready to install in 24 hrs.
Hope this help all that are are this point in their restoration process.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Awesome info, thanks for the writeup!
Project79'
Pulaski Va.
Dusty
K10 Cheyenne
350 sbc centerbolt heads
Great thread. Actually in the process of doing all my plastics just like the picture you posted. Will definitely use this process!
JTWard
SE Pennsylvania
James
C1500 Silverado
350 Gasoline
Unless you want a huge mistake with your colored interior parts ( I did this and Wow What an education ) I have tan interior and I tried to touch it up ? Well the Acetone in the spray can will make you black spot a huge spot. How I did not know, but soon learned, ALL interior parts are black at the factory when they were made, and then painted to the customer choice. So be forewarned, touch up with a spray can and shoot a little bit into the cans cap and use a paper match stick and gently touch any spots that have been nicked. But as the OP has instructed, get a clean garage and a lot of time and clean and respray the scuffed up interior panels.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
great write up!! :dogpile:
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Great write-up! I'm a newbie and am really getting an education on this site. Thanks.
Just saw this, but it needs corrected. The plastic panels were molded in color at the factory, not painted later on. Any panel that was painted, was more than likely a replacement part.
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Very informative write-up for those of use that are new to painting interior parts. Thanks for taking the time to share this information, especially the proper products with pictures! Now I know where I went wrong in the past!
fried_daddy
Birmingham, AL
R1500
5.3 LS
Nice write up. I'll be using these steps to re-do all of my interior panels.
78C10BigTen
pennsylvannia
C10 BIG TEN
Is this still the same for the dash pad?
Steve78 k10
Tennessee
Steve
Good info. I literally just finished all my kick panels and door panels. I did exactly like you have just different brand on the adhesion promoter and the paint. I went with dupli color. Turned out good would post pics of my rebuild but Everytime I try to upload a pic there is a file problem.
jeremyb
dallas
jeremy
Thank you for this write up. I followed it exactly and they turned out as good as new. Nothing like saving a few hundred bucks!!
Brian Bonehill
Dallas
Suburban
I have used and am still using Colorbond LVP bought from LMC. I have done the entity of the headliner trim and all the window trim. I am converting my all smurf blue Suburban to a blazer grey interior. The colorbond is amazing stuff. Spendy...but worth it, in my opinion. I have used 4 cans so far to do all the interior trim and now and doing the door panels.
I washed / cleaned all the parts with greased lightning first to remove any dirt / grease / grime. Then I wiped down the entire painting surface with 100% rubbing alcohol on a lint free rag. I have used 2 coats on each panel and when dry; you cannot tell that they were “painted”. It is painstaking but rewarding. Here is a of the pic of the progress.
I cannot more highly recommend the colorbond lvp product.
goodwrenchca
