- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I was reading to see if anyone else was going to suggest that. I see it too. It seems to run from the bolt hole to under the water jacket and down into the valley.Looks to me like coolant was leaking between the head and intake, at the rear port on the driver's side. It looks like evidence of rusty coolant leaking past the gasket.
And BTW, that's looks like A LOT of water in that valley. It's not even mayonaise like and churned up with the engine oil yet. Soooo, pull your dipstick and compare. You're probably going to find there's not near that ratio of water in the oil pan yet. With all that water in the valley, you can just about be certain it leaked there from the intake and has laid there and didn't make it to the drain back holes yet and get into the engine oil system. Certainly some did already but with that much water laying there at that ratio of oil/coolant I'd say that's where the problem is. And it does appear to be at #7 water jacket if I had to guess based on the pics.
