MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
hmmm I do not have voltage drop with the stock wiring.
I did how ever have the same problem and it turned out to be the ground wire to the cab fire wall was the issue. When I upgraded the ground wire and hooked it to the alt pad with the battery negative cable my voltage came back up to 14.10 inside the cab when engine is running.
