Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
new 4 wheel disc proportioning valve came today with some other stuff.
does anyone know the output of a 86 hydro boost 2 return steering pump versus a 96ish vortec era steering pump? I know the vortec pump can be run with two returns t'd into one, but I'm liking the dual return for capacity and it's intended purpose was hydro boost. I've pulled both pulleys and confirmed the shaft is the same diameter and length, so I can press the serpentine pulley onto either. they also both appear to have the same hole pattern on the pump itself. should I run the 86 pump with dual returns? should I tap a second return into the newer pumps reservoir? should I swap one pump into another reservoir? what combo would be best? I have a rebuild / o ring kit for both.
86 pump with three returns native to the hydro boost:
vortec era pump with a single return line:
the vortec era pump has the same mounting hole locations, so using the older dual return pump with serpentine brackets should not be an issue either:
