Pic of the clutch rod on a 4 speed where it goes through the floor, I replaced my floors and need to drill the hole for the clutch rod. Much appreciat
Gman73
Sacramento
Gary
Ck20
350 v8
Pic of the clutch rod on a 4 speed where it goes through the floor, I replaced my floors and need to drill the hole for the clutch rod. Much appreciated
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Looks to be immediately below the gusset plate for the column/brake booster and just to the right of the bolt.
Gman73
Sacramento
Gary
Ck20
350 v8
Thank you so much CalSgt that's exactly what I was looking for.
Beanz2019
Kansas
Neil
I believe there are 3 divits or small indentations on the inside firewall just under the cut out for steering. They are at a slight angle. The two outside indentions are for fasteners and the middle one is for you center hole that I think is 2" in diameter. These should help with alignment/positioning.
I could be mistaken though.
Gman73
Sacramento
Gary
Ck20
350 v8
Got it thanks all
kobedemello
