usar17
- May 3, 2012
- PA
- Shawn
- K20 Silverado
- TBI350/700r4/NP208
Ok, Frankenstein truck here. 85 body and frame but...
1991 TBI 350 Engine
1991 K5 instrument cluster
1994 4L60e Transmission
1991 NP241c
1994 Wiring harness, VSSB, PCM
I have tried 2 different PCMs and 2 VSSBs, but the truck starts in 2nd gear. I haven't gone fast enough to see if 4th works yet. Speedo doesn't move till around 30 MPH, but the ALDL data shows accurate speed to PCM. ALDL datastream is showing proper column shift position, and proper function of Solenoid B for 2-3 shift. OHMs test of Solenoid A is good, 12v test I can hear solenoid activating. All wiring is good, no shorts that I can find. With transmission harness unplug the ALDL data is still showing the PCM commanding 2nd gear from the start. This is a frame up build so all parts are new to me. Just ordered a new a new Speed sensor from Rockauto today to try that. Wont activate Solenoid A even with shifter in 1st. So something is making these PCMs think it 2nd gear is needed. thoughts, im losing my mind here
1991 TBI 350 Engine
1991 NP241c
