Parts...Parts...Parts...
Hey @Mr Clean .... do you still have some spare gas door springs from your tail light mod? I'd like to grab one from you, sir. Just tell me how much :)
RealDaveMaggio
DC
C10 Suburban Estate
Battery Tray
Mr. Clean, do you have a battery tray for a 78? Mine is all but rotted away.
I have the tray, band new. I don't have the side panel. I have some one that said they wanted it, but that was like 3 months ago.
Just to let you know...you can replace your whole battery tray assembly from LMC for like $45.00 bucks. That is brand new tray, and side panel. If you only need the tray is like $14.00 bucks.
Jamal
Alton, IL
Jaymie
I need a wiper motor...
swbchevy
AL
c 10
I need a set of 2wd front stock spindles for a 1981 GMC Jimmy.
I have a set, do you need rotors, or just the spindles? I am assuming 1/2 ton
I was going to ask 1/2 ton too, cuz I have a 3/4 ton set. Being it's for a GMC Jimmy, they only came in 1/2 ton so you'll be the one to hook him up on that. :waytogo:
swbchevy
AL
c 10
Just the spindles for 1 1/4 rotors. I also need a throttle/kickdown cable bracket for a 1985 silverado c 10. I am looking for the one with a hole for the power brake vacuum line to go through. thanks.
I'm still looking for 3/4 ton K20 4x4 Front Brake backing plates for a 10 bolt front axle. I have the 10 bolt axle in K10 6 lug. Needing to convert it to 8 lug. Figured I'd just buy new rotors in 8 lug, the calipers should be the same, the lock out hubs appear to be the same, but I've been told the backing plates are different. If anyone has them cheap or sees them in a DIY parts yard and willing to pull them, lemme know please.
I don't know what size they are. They did come off of my 82 Blazer. I just gave the bracket to one of the guys I work with last week. I'll look in my spare box of stuff to see if I have another one.
yevgenievich
Place
Name
Year
Model
Size
I have a set of spindles from a 90 2wd suburban if they are the same.
Also have a wiper motor from 84 jimmy i believe.
jimlayhee
