"Overheating" --> Now Fuel Delivery Issue --> Dirty Tank?
Bruce Wingate
Long Island
I've got a '87 and up baffled tank waiting for the LS swap. Am I correct that the mechanical pump sending unit will fit in the newer baffled tanks?
Bruce Wingate
Long Island
Sounds like you might be sucking air, as stated up thread, a fuel line with under suction may be cracked or compromised, but being under vacuum it won’t leak.
Maybe get some 3/8” fuel hose, disconnect the drivers side tank feed from the switching valve and draw from a gas can on the ground, if results change the problem lies from the switching valve to sending unit on drivers tank.
This sounds simpler than dropping and switching tanks. May also swap left and right inputs to the switching valve to make sure that is not the problem.
Hunter79764
Grand Prairie, TX
Suburban V20
Agree on all above. To get into troubleshooting mode, you are likely looking at an issue on Driver tank only, possibly obstructed pickup, possibly cracked hose sucking air, possibly a combination, and possibly something different. Your "known good" point is probably the line leaving the switching valve, everything backwards to the driver tank cap needs to be checked in whatever way is most appropriate until you find the culprit.
My preferred route is to find something easy access, roughly in the middle of the system and test there. If the problem stops, you have a new "known good" point, and you test at the next easiest point in the middle, and so on.
For this, I'd start at the 3/8 line going into your selector valve from the driver tank like Lego said. If it works fine, you can try just replacing the hose from there to the sending unit. If that's it, you found your air leak and party on. If not, you are probably looking at dropping the tank and your issue should be relatively easy to find from there. If the new line and gas can doesn't fix it, then you are probably looking at the selector valve and/or connections to/from it. Replace more hose and clamps (since that's never a bad idea on an old truck) and see when it starts working.
Ajax19
Socal
Ajax
Mine was the 40+ year old in tank fuel sock
I think I have it fixed. All this was used by a 3 inch peice of hose. Which was 7 years old. Ran the truck for a while with no problems.
Thanks for all your help and suggestions
chevy c20 65
