- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Yes and no. Vapor lock happens before the pump... where there is a vacuum being pulled by the pump. The vacuum being pulled by the pump pulls the boiling point down very low and causes vapor bubbles in the line that the pump can't move. A three line pump will constantly move a large volume of fuel through the system, which usually is enough to keep the fuel from warming up enough to vaporize in the line. It can still happen though if you have a restriction in the pickup tube that causes a higher vacuum to be puled in the line before the pump. Modern EFI engines don't have this problem because every bit of the fuel system outside the fuel tank is pressurized to 3 Bar or more of pressure, which raises the boiling point high enough for it to not matter. Also EFI pumps push while they are submerged in fuel, so there is nowhere for a vapor lock to occur as long as there is fuel in the tank.Vapor lock more times than not is caused by low fuel pressure.
Think of it like a pressure cooker. Boiling point increases with pressure. Today's fuel is not designed for carbs, exacerbating any low fuel pressure issues.
