Overdrive Trans or Ring and Pinion swap?
Any idea if the transmission crossmember from the th400 will work with the 700r4?
Should be fine. I think it is just a different mount, not a different crossmember
Just Mark
Michigan USA
Mark
C30 Camper Special
Cool, thanks.
I did some digging in to the Gear Vendors Overdrive. Does look like the beauty way to go. Also, outside what I can afford at the moment.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Gear vendors overdrive may not be the cheapest option, but you would keep the strength and towing capacity while lowering you highway cruise RPM.
I plan to install a Gear Vendors unit in the spring, even after swapping my 4:10s to 3:73s.
Dooley
North Coast
RW
V30
When I ordered my last 2 wheel drive dually in 1976 it was in May of that year.
They had a shortage of Dana 70 axles that summer and when mine arrived it had a Spicer.
No problem, it worked great Just a good ole 454 with 3.73 gear.
What? Spicer is the axle and driveline brand name of Dana incorporated. Dana and Spicer are the same company.
SquareRoot
Lol. Good point. All I have to offer this no-brainer thread is a th400 still lacks a lock up converter. 4500 or go home. 4l80 otherwise.
SquareRoot
OP, buy once, cry once I might add. Carry on.
Dooley
North Coast
RW
V30
1976 they had a shortage of what was referred to as the "motorhome" axle in slang language.
This rear differential did not have a threaded fill plug in the housing, but a pop in fill plug.
It had the name "Spicer" right on it. That made that axle different than all the others I ever had or seen.
I bought 8 new dually pickups over the years and know what I had. I know about Dana Corp and Spicer history.
cstew47
colombia
craig
It usually works. You might have to drill a few holes in the frame to relocate the mount.
1978kustomc10
