Old Delco 2700 "ETR"
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I think this is the same family, I had never found one that was fully functional until today. It is a 1982 with a repair tag from 1987. I can cut the long, plastic mounting ears to use in my truck (AFAIK, if I decide the swap out the newer analog Delco). I should have taken a picture of it in operation. No tape.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Is anybody actually good at fixing these things and maybe adding some updates? Even an Aux connector would be good enough to add some capability.
I still have the one from my Suburban, and it was working fine except the screen was a little flakey. If you pushed on it, it would display properly. Other times it is was hieroglyphics.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Could those wires be for a power antenna?
by that time all squares had antennas built into the windshield. It's already been said a few times, but that wire is a constant hot for memory.
RoryH19
Rory
R10 Silverado SWB
Had the same issue with mine. There is a radio shop close to me that had to resolder all the connections.
Been working for several years.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I can do this stuff, but seem to lack the motivation to get it set up on the bench (lacking space, coffee table and dining table set ups). If I use the 'new' one, I may have to add the aux input. I've added them to all our cars
Royal
Nh
Do you have a diagram for the 2700 etr stereo
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I do not, unfortunately.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Name and address please. :worthy:
skarletjunkyard
