OIL
Mango
JacksonWyoming
Gil
Hey All
How often do you change your oil in your old Chevy 350 with High Miles ?
legopnuematic
Licensed Junk Dealer
MO
Spencer
3000-5000 depending on driving. Lots of short trips closer to three, nice highway driving getting things nice and up to temp I have no issues with 5000.
Quality air filter, working pcv system all help keep oil cleaner. I also always run the larger oil filters (used on medium duty’s) and always Wix filters (or other quality equivalent).
fast 99
Spokane, Washington
3000 is rule of thumb. To know actual oil condition at change interval, get an oil analysis done by someone like Blackstone. Results are very revealing in other areas as well.
Mango
JacksonWyoming
Gil
Ya all Sounds grea!t I was just curious. I do a oil change every 2500 to 3000 and do have my oil analysis done through work it was very bad for a while now its back to OK with some common metal wear! Use 10w-30 regular oil with Lucus Heavy Duty oil stablizer 1qt
CheemsK1500
K1500
Honestly, I’m just glad to find oil still in it more often than not.;)
On a serious note, 3k to 4K seems reasonable. You could maybe even push it to 5k with certain synthetics. The overall condition of the engine in question could play a part too. This is definitely a “Mileage may vary” type answer to such a question. Also remember that even you “waste” oil by changing it too early, you’ve still spent less on the new oil and filter than you would’ve on an engine replacement that results from habitually changing it late, if at all.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Between 3-4k on anything I own. New or old. Synthetic or conventional. Lucas oil stabilizer and 10-30 oil with a wix or Ac Delco filter. Everything I have is gm.
I’d look a bit deeper into the Lucas. Everything else sounds good.
Mango
JacksonWyoming
Gil
@Frankenchevy What good or bad with Lucus? There is a lot of snake oil out there
I want to add something, miles is not the only consideration with oil changes. Time is also a consideration. Change oil at least once yearly. The oil mixes with oxygen,condensation,etc and can sludge up in oil passages and or become acidic,etc. Just be cause you only drive your car 500 miles a year in parades,doesn't mean you can change the oil every 6 years. Yes that's an exaggeration, but it makes the point more clear.
Octane
Atlanta
Eddie
I want to add something, miles is no the only consideration with oil changes. Time is also a consideration. Change oil at least once yearly. The oil mixes with oxygen,condensation,etc and can sludge up in oil passages and or become acidic,etc. Just be cause you only drive your car 500 miles a year in parades,doesn't mean you can change the oil every 6 years. Yes that's an exaggeration, but it makes the point more clear.
I drive my 77 K10 1k to 2k per year.Change oil each year because of these reasons.My truck is parked outside in the weather also.Not in a climate controlled garage
350 w/203
Change mine every 3K or so. I use K&N big filters (used to use GM) and a magnetic oil drain plug is a good friend too.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Lucas is basically a filler that dilutes your oil’s additive package. I read a study where Lucas was used with many name brand oils and it universally caused more wear and issues based on oil analysis.
Modern oil shouldn’t need any additive’s. If it does, you are using the wrong oil. There are quite a few experiments surrounding oil, additives , etc. none of which have been conducted by myself. So consider everything I type here as me just regurgitating the studies I’ve read.
Octane
Atlanta
Eddie
I put Lucas in a hemi once and it made the engine noisy.I drained it all out and never used it again.An oilman told me that motor oils contain stabilizers.And adding more to their balanced mix just wasn't necessary,and only messed up the proper additive package balance.And because of each brand having different detergents,to not mix brands of oil in the same engine.To get the best benefit.I can agree with this, If anyone doesn't,it matters not to me.I do me,you do you! Lol
Brandon121
