MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
High volume oil pumps are good to use. Just make sure the drain back passages are clear and you won't have issues.
High volume oil pumps will require loose clearances. You will ruin the bearings on the center journals.
I thought it was only the High Pressure pumps that required looser clearances ?
