Oil Pan Gasket
Mango
JacksonWyoming
Gil
Hey All
I seem to have oil leaking a little and getting worse, just replaced intake Manifold Gasket, Plenty of goop on the wall of China, unless it fell off?
But its been dripping a little before the install.
Rear Main Seal Flex Plate no Oil
Does this year have a one piece gasket or old school?
Thanks
fast 99
Spokane, Washington
Really doesn't matter what is on it. If leaking needs replacement. Use a 1 piece if in the vehicle, small dabs of silicone on the parting areas.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
What really matters is thin or thick pan gasket.
ChuckN
Bellinham, WA
Chad
I used this on my mid-70s 350. No leaks, and the snap-ups hold the oil pan up while you get the bolts started. There are also metal collars that keep a fella from over tightening the bolts.
I did put a little ultra grey in the corners where it curves around the rear main and the timing chain cover. For thirty bucks, I’d use them over and over again. Edit: it’s rubber silicone with a steel core.
Mango
JacksonWyoming
Gil
How to tell if oil pan is leaking or Rear Main Seal
Rickf
Grafton NH
1974, 1954 & a 1937
You might try some of the dye that's available and a black light.
Mango
JacksonWyoming
Gil
Thanks
I also dented the oil pan a while back replacing the engine motor mounts. May have caused a very weeoing leak? Should i also install a New Oil Pan?
germando
dfw texas
Justin
c1500
Pull the flywheel cover usually a rear main leak will get thrown around inside while the pan leaking just drips
G
Mango
JacksonWyoming
Gil
Fel-Pro Gasket Install should I also replace bolts with new ones
Rickf
Grafton NH
1974, 1954 & a 1937
If the heads of the bolts aren't rounded and the threads are ok, use them.
tmssldn
