Oil in the “heat passages” on BBC 360 heads
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I was surprised to find lots of oil in the passages between the #4 and #5 exhaust over to the intake manifold on both 360 heads. Should I be? Cracked heads? Blowing in from the exhaust stroke? Thanks.
AKguy
Alaska
Randy
Hmmmm, thanks.
nvrenuf
Mobile, Al.
@AKguy was it liquid oil or carbon build up? That's an exhaust crossover for the choke or EGR, etc., I've seen carbon build up in there. Performance intake gaskets have a block off plate to help the intake stay cooler.
Old Guy Bill
KY
Bill
Is the PCV system operational?
AKguy
Alaska
Randy
Liquid oil.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Like Rick said, an added is benefit is slightly more HP, for free. David Vizard did some interesting studies on that, plus helps with oil leaks.
jmcbil24
