Odd hesitation
350runner
tx
Ceasar
Haaaa!
Boone83K10
Boone, NC
Benjamin
350runner
tx
Ceasar
yeol1
East TN
Joe
Cat as in catalytic converter. You shouldn't have one on a 73 but since the PO did an engine swap it wouldn't hurt to check.
Also check the gaskets for the fuel pump if you have a mechanical fuel pump. My truck would have a similar issue because it would blow out the gasket on the fuel pump. It would idle fine but when I gave it gas it would suck more air the gas and bog down and die
73K20
Jake
My trans is new just put in. It was getting around 12mpg and the worse the problem got the worse my mileage seemed to get and my test drive last night was maybe 15 miles and it drank almost a quarter tank.
Anyone think a coil could give these symptoms?
1993 F250 3k in the 460-my 1st truck
1973 K20 6" lift-bright future
1967 F250 2x4-diesel swap in its future
73K20
Jake
Oh and no cat
350runner
tx
Ceasar
Trans fluid level?
73K20
Jake
It's full and all new
350runner
tx
Ceasar
Good. Where is your timing set at and are you using vac advance?
73K20
Jake
Timing no clue. Where it's been since it ran perfect havnt touched it. Just replaced the coil, the readings on the old one were off a bit. Helped alittle, drivable but still not better
73K20
Jake
Any chance it's a lifter sticking?
350runner
tx
Ceasar
Lifter sticking would run real bad. I'd start with the timing. Try removing the vac advance hose and plug it then go for a drive.
73K20
Jake
Ok it started doing it really bad again. plugged the vac advance gonna try and drive it again.
73K20
Jake
Same thing started bogging down about 40 in 2nd. Up to 3rd. Difference this time was if I kept my foot in the gas a bit I could still speed up slowly. Before I lost all power completely.
Evens out about 60 and now on the freeway it stopped bogging down. Very intermittent.
350runner
tx
Ceasar
Timing gun :) you should check the timing
PDlane200
