Nv3500 into an 86 k10, but not a normal swap.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Okay i have kind of an odd situation. Looking to swap a NV3500 into my 86. Found alot of threads here, but no one has my exact situation.
I have an 86 GMC K1500 shortbed.
350, SM465, and NP208.
I have 4:10 gears, so it screams going anywhere, eats alot of fuel. Was looking for a trans with OD. Bought an NV3500 out of a 98 k1500. Seems like its a good swap, but i do have a few questions.
I took measurements and the lengths look perfect. Case length is the same, mount location is the same, bellhousing is the same, round bolt T-case pattern is the same. From my research, the output shaft spine count is the same. Shouldn't need to change drivehafts.
I have a hydrualic clutch already, and according to some YouTube videos ive watched it says i can use my 80s cutch master cyl, with that internal style 98 slave cyl/release bearing if i run an adapter fitting.
Now my biggest issue i have is i believe, i will need a differnt flywheel and clutch set.
Now id just buy a set for a 98 and call it done, except my 350 in my truck is out of a 86 corvette, and the flywheel bolt pattern is the larger internally balanced SBC and BBC type.
Cant find any info on what type of flywheel i would need to buy. Kinda lost there.
Also not 100% sure if the YouTube info i got on using a stock master cyl will work. If not, what would i need? Would a 90s model master cyl bolt up? Or what adapter fitting do i buy.
Anyone here have any answers or been threw the same thing, i would greatly appreciate help. Thanks.
Redfish
Prairieville, LA
Andrew
V1500
I don't have any answers but I am really happy to see you posting here again!
I had that transmission in a '95 GMC and I loved it. It would certainly be a more useful and modern transmission in your '86.
Sorry I am no help with your problems.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thanks. Im still alive, just alot going on. Haven't been real active here, but still try to check in now and then. Still working on my squares fulltime though, haha.
Glad to hear from you again!
Are you sure you're engine is an '86? '86 was the first year for a 1-piece rear main seal with the smaller crank flange.
Also, it's my understanding that the 3500 uses the typical type Chevy clutch and flywheel setup. So it's just a matter of getting a clutch disc to match the trans, 10 or 26 spline.
I believe it's @bluex here that has swapped the 3500 into a truck with an older 350.
Squarebuddy
