NP208c transfer case gasket set ?
Rocky Veley
Ontario Canada
Rocky
Good Day. The np208c transfer case in my 85 K10 is leaking and works fine. I picked up a spare 27 spline np208c transfer case to rebuild. It works fine on the bench . Case looks good and shifts ok. I would like to get a gasket set for it. I don't like liquid gaskets. There are many different rebuild kits ranging from $17.00 up to $130.00. I don't see any with gaskets. At least not the big one . Confused here. Has anyone been through this ?
Thanks in advance for any info.
chengny
http://www.allstategear.com/NP208-Gasket-Seal-Kit-s/2345.htm
$25 and it appears to have the "big one".
chengny
I think he's talking about the big full case gasket where you split the case. I've not been able to find a kit with it either.
I think that if he wants a gasket between the casing halves, he'll have to make one. The faces of the casing halves are machined surfaces and don't require a gasket - just a light coat of sealant. A gasket was never available as an OEM spare part. Matter of fact, use of a gasket might alter some internal clearances. If he does make a gasket, it should be cut out of very thin material - like chart paper for example.
From the NP208 shop manual:
Right, I believe that's what he's wanting and I don't think it exists.
highdesertrange
kalifornia
mike
k30
no gasket on the case halves is correct. lite coating of RTV is what we used to use. highdesertranger
Rocky Veley
Ontario Canada
Rocky
Thanks a ton lads. I was looking for the big gasket . I had never considered that they came factory without one . Great forum !
zapattack
