PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- 84,79,77,76,70,48
- Suburban k10, bonanza k10, k30, k20, c10, gmc 1/2ton
- 350, 350, 350, 350, 350, 350
@RanchWelder
This is the one I ended up using, seems the part number is discontinued, only did a small search though.
The flange surface ended up being the exact same height, pilot and bolt holes were correct. Haven't had a leak since. The spline count is 32, don't forget the rubber spline washer.
I found this that seems to be the exact same one, just a different part number because of torque king instead of quad 4x4z but says it's backordered maybe? Same numbers after the letters.
You should be searching for Chevy or dodge output yokes. 32 spline. Then the only other real important part is the pilot ring size. The driveshaft should have 3r u joints. I believe the off-road design ones would have worked.
I have a 208 I'm not using at the moment I can measure. That quad 4x4 part number exists because I believe that company sells on torque king.
TKA10935 32 Spline Front CV Flange for Dodge NP205D, N208D, NP241D, GM NP208C, NP241C
Order your QU10935 front output CV flange today at Torque King. This genuine NPG balanced NP205 front output CV flange works with 1975 1/2 - 1993 full-sized Dodge 4x4 trucks with NP205, NP208, and NP241D transfer cases. Shop for your new Dodge front output CV flange online at Torque King 4x4!
torqueking.com
