NP208 to NP205 T Case swap
M86K10SS
Lakeland FL
Mark
I have an 85 K10 with a SM465 and a 208 T Case. My neighbor is selling a 78 SM465 and a 205 T Case. How difficult would it be to swap in the 205, would I need different drive shafts? Will the linkage be different? Any help would be appreciated.
You would need the SM465 from the '78 as well. That 205 is the "figure 8" mounting pattern and has a 10 spline male input. Your 208 is a "round" style mountain pattern and has a female 32 spline input.
I think my truck has the same setup as your current one, prob from the same year. But then I also have a setup from a 77 k25 and 80 k25 and based on that, I would say you probably need a different length driveshaft especially because the rear output is probably a flange on the 78 and not a slip yoke. can you get his driveshafts? front may be the same..maybe.. you also probably want his flat crossmember because that figure 8 has feet on it that are meant to set on a flat one
Obullard74
