Not digging np203.
ight i just talked to the guy the 2 14b are both ff 8 lug 4.10 gears. ima prolli make the trip this weekend then. As for the front... that dana will bolt right up right? assuming i can fix it.
Is he holding them for you? Those will be long gone by this weekend at that price. Chances are they are 3/4 ton. If they were 1 ton, then the front would likely be Dana 60. They're going to be pre 78 3/4 ton axles if my best guess is right.
Yes, the Dana 44 will bolt right in. (If it's a GM front axle). Should be, Dodge didn't use 14b FF.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
ill ask him to but lol his add has been up since 7/15 also the dana has a bad R&P and missing a spindle.
Really? Those wouldn't last half a day at that price here.
Kapdin
North Dakota
Lance
Ok i need to stop shopping for square parts but i think i have found a good np205. Its very clean and specificaly states th350 adaptor but i don't see any shift linkage. I e-mail the guy so waiting to hear back but will my np203 linkage be the same?:shrug:
NOT the same. But that's just a good excuse to twin stick an NP205. You can get a Twin Stick Shifter for about $110 or so.
Kapdin
North Dakota
Lance
LOL i just read a write up on twin sticking a 205 omg id get confused but deff. cool. Other side is im not the only one going to drive my truck sooooo thats kinda risky.
If someone gets confused with just one extra lever on my truck, I wouldn't be letting them drive it either. In fact, I wouldn't let them use my lawnmower. :roflbow::roflbow::roflbow:
Wildjoe330
Right Now
wildjoe330
Itbp
HaS ANYONE rebuilt a np203 and found the front of the output shaft
Lose like it needed a bearing on the front end of the shaft???
Take Aways
He just needs a 27 spline with coupler adapter for an NP205 I do believe. Th350 is gay and has 2 male trans output and T case male input shafts. So you need a coupler as a ***** to join the 2.
http://www.offroaddesign.com/catalog/transfercaseparts.htm
77 K20, 50 to 65 pulsating Vibration, Was Full Time, Replaced front axle u-joints, Cab Body Bushings, Front Wheel Barrings gone thru, Upper Lower ball joints, New front pads, New Lockouts, Used Part time Kit, Rear drive line Balanced New U-joints, New Tires/Rims Balanced, New Transmission Mount, 350, TH350, NP203, 7/14 10:22
99tan99
