No crank, no start
WP29P4A
Nevada
Sierra Classic V1500
Could the "plastic portion" be the identifier/label showing the value of a fusible link, does it have a number on it?
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
You're going to have to cut it anyway to make a connection. Your pic with the starter in it makes me think that the red wire is the fusible link and it should be on the starter big terminal that's the one that will be feeding power to the ignition switch. The purple one probably broke off of the S terminal, a small terminal. I'd go ahead and put a ring terminal on that one and it should have power from the ignition switch start position if the ignition switch is getting power from the red one at the starter.
Yeah, I'm definitely going to have to cut it off and put a new ring terminal on it. I've just never seen anything like that before and figured it probably served some purpose.
The red wire definitely has a fusible link.
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
I didn't see a number or any writing on it. The red wire even has "Fusible Link" written on it to help identify, but I didn't see anything on the purple wire
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
Alright. Got a chance to get back to it this weekend. She's back in action!
Seems like there were two simultaneous issues:
1) The ignition switch
2) Bad connection on the "s" terminal
A few weeks back, I put the new ignition switch in, and it started up once or twice. I put the old one back in, and then moved on to the starter. I fixed the connection yesterday, and all the dash lights, buzzer, windows, and fuel pump worked. However, when I went to start it, nothing...I realized the old ignition switch was still installed. When I put the new one back in, boom. It fired up, and the problem seems to be fixed.
Hopefully someone else can see this an save themselves some time if they have the same issue.
Up next: a tune-up, address the slower power steering pump leak, replace transmission pan gasket, and get a new overflow tank for the antifreeze. I'd eventually like to get a set of these helper springs. https://www.hellwigproducts.com/products/search-by-vehicle/?Year1=1989&Make=GMC&Model=V2500+Suburban
And of course, I'm still seriously considering an LM7/LQ4 and 4L80E swap :D
Thanks for the help, everyone!
Royal Sierra 454
Goodyear, AZ.
Scott
15 GMC Royal Sierra
I would check the NEG. Battery cable to the engine block. Use a Star washers to get a good ground. Had that issue on my old Pontiac.
Stringfellowhawke
Maryland
Dre
Suburban V2500
I have a 91 Suburban V2500 3/4 ton with 350TBI
I been having a similar issue no crank no start. The battery and alternator are brand new, the starter is still strong. I also put in a new neutral safety switch, ignition module and cleaned all the ground straps and made sure they were tight. When I was driving it shutoff without any warning luckily there wasn't no traffic. I attempt to restart but nothing the headlights, interior lights and warning buzzer all work.
I'm starting to think it could be related to those fusible links and junction box
gmbellew
Kansas city
glen
suburban 1500
I'd take a hard look at the 440 circuit (orange wire) in the main harness across the firewall for rub through on the variois brackets (MAP. cruise control, etc). it feeds power to the ECM and fuel pump relay. it won't explain your no crank, but it will create a no start and will kill the truck while driving if it is shorting to ground when going over bumps.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
Thanks for following up on what you had found/fixed. "Hawke"
Raisen
