No accessories power
legopnuematic
Licensed Junk Dealer
MO
Spencer
I think @Snoots has got it, when you turn the key to Start or run position it pulls on the switch (rod moves up towards driver), so accessories position pushed rod away from driver.
Easy to get confused laying upside down under the dash trying to think that through… DAMHIK
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
It's located near the bottom of the steering column.
There are 2 screws holding it there.
Loosen them (don't remove) and you can move the switch.
I'm guessing here but I'm thinking you'll have to move it towards the steering wheel.
Turn your radio on and turn your ignition to the ACC position.
When the radio comes on, You've found the spot. Tighten the screws and enjoy.
^^^^ Basically this
There may be a bit of a compromise on the best position for the ignition switch. When its perfect each key position should work accordingly and the key should snap back to "Run" after cranking. It may take some trial and error to get it perfect.
I'll add, do not attempt to bend or alter the ignition switch rod that comes from the lock cylinder.
These switches do wear out also, the contact points inside the switch may get dead spots in them.
Dukester68
Gary
c2500
^^^^ Basically this
I located this switch however the only adjustment i found was the hi lo beam switch. None in the ignition but i did use bent needle nose to gently force the rod back about an 1/8 of an inch and the accessories did come on. Im thinking my problem is in the gear off of the switch?? Im going into the column today. Thx
CalSgt
CA
Casey
There should be 2 screws holding the switch to the column, the holes in the switch are slotted allowing for about 1/4” or so of adjustment. These screws are hard to get to and usually are removed/loosened by feel.
If the adjustment does nothing either the switch is worn out or the ignition rod assembly is probably broken. The rack which gets driven by a gear attached to the key cylinder is a common break.
CalSgt
CA
Casey
Here’s where the screws should be
Dukester68
Gary
c2500
Yes you are correct!!! I went back in because i tore into tge steering column and got no happiness there. I did adjust it to where i got the accessory power but then the ignition switch didn’t work. I went back and forth and finally figured i need a switch…. Do you think that will help my situation? Tgank you again for you expertise in this area. Im learning alot. Lol
CalSgt
CA
Casey
Couldn’t hurt…
New switches aren’t terribly expensive and you’re probably due for one.
If you can feel the detents in the switch and everything works as it should in the different detent positions,my money is on the ignition rack is cracked or the rod is bent. Easy to check,pull the switch off but leave the wires attached run the switch through its positions,I use a small screwdriver to slide the switch from position to position.
Dukester68
Gary
c2500
Man i got into that column today and that was a job. I got as far as pulling the turn signal harness as far as i could and realized it was going to be a job. How in the world do you get enough slack to pull that column? I pulled the plug apart that the signal wires were attached to and it didn’t help much. Lol. I lubed everything up and pit it back together but had to take it apart again because although i had achieved what i wanted when adjusting for accessories power, it wouldn’t pull the rod for starting. You are probably right though…. Probably the gear rack is missing a tooth or two.
78 squarebody
