New to the group
J011YGR33N
Luke
K15
Carb 350
Hey guys I bought an 87 V15 long bed back in July. I’m retired so I needed something to keep me busy. Unfortunately I found that the frame is bent in a few places so I’ve been searching the net for a replacement frame near coastal Georgia. If any knows where I can find a replacement I would be forever grateful.
WFO
Texas Panhandle
tpripps
Scandia, MN
Tyler
C30
Welcome from MN!
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Welcome from the land of rust! (New England)
Is the frame kinked or cracked anywhere, or just a little twisted? A frame shop should be able to straighten it for pretty cheap, hell of a lot less work than doing a frame swap and IME it's usually only a few hundred bucks, probably no more than you would spend on another frame (if not less)
Auburn, Washington
^ My thoughts as well. Pics can be deceiving but it looks good
animal
Lee
c10 silverado
350ish
:welcome:
J011YGR33N
Luke
K15
Carb 350
There’s a slight twist in front on the driver side, a kink with crack on the front passenger side , bent front crossmember, a superficial bend at the end of the passenger side. Only 1 out of three places here was willing to work on the frame and they want $800. The rest of the truck is solid. I found a possible replacement that is complete minus the front clip for $1500
Babs
Ottawa Valley
Chevrolet CUCV
1973c10
Don
Welcome aboard
FWIW, any 1/2 ton longbed or 3/4 ton 4x4 frame from 81-87 should be a direct swap. I've seen several frames just sitting around here for $100 or so, but I'm on the other side of the country from you.
GMCk2500Dalton
