New here Tranny swap question.
k5inAJ
apache junction AZ
Robin
k5
Can I swap an 88 burb to a stick with a 77 k5 pedal assembly? will it just bolt in?? Got a dead k5 rustbucket and access to an 88 burb with a bad trans and good motor. Both 350's Thanks!!!
SquareRoot
I'm guessing you're too young to have grown up with one of these?
No it's not just going to be a bolt for bolt swap. Are they both Ks?
Strick
Dunn, NC
Harold
C20 Crew
The 77 is mechanical release where an 88 would be hydro. Use all the pedal assy & z-bar stuff on the 88. Driveshafts will differ & you'll run into a few other small issues...but it's very doable.
HS
Flywheel is different also, not sure about speedo drive. I'm assuming they are both 4wd
Obullard74
